Shutdown Report Manager
- On the SDM server, log in as the nncentral user.
Change the
			 directory to the bin directory.
For example:cd /home/nncentral/AcmePacket/NNC<version>/bin
Execute the
			 shutdownnnc.sh
			 script. By default, the shutdownnnc.sh script detects whether the existing
			 installation is a standalone or clustered system and prompts you with the
			 option to shutdown the entire cluster if no flag options are provided.
Note: However, you can script an option ahead of time by adding -local for single nodes and - cluster to shutdown an entire cluster../shutdownnnc.sh Shutdown back-end server Do you wish to shut down the entire cluster (Yes/No)? Yes
- On the server where the Oracle database software and BI Publisher are installed, login as the Oracle user.
Change to the
			 WebLogic server directory. For example:
[oracle@vm ~]$ cd /home/oracle/Oracle/Middleware/Oracle_Home/user_projects/domains/bi/bin
- Stop the WebLogic server. Go to the Manage the WebLogic Server section for more information.
Stop the BI
			 Publisher database instance listener (LISTENER).
[oracle@vm bin]$ ./lsnrctl stop
Stop the OCSDMDW
			 database instance listener (LISTENER2):
[oracle@vm bin]$ ./lsnrctl stop LISTENER2
If undefined, set
			 the ORACLE_HOME variable in the .bash_profile of both the oracle user and the
			 nncentral user.
export ORACLE_HOME=/home/oracle/app/oracle/product/12.2.0/dbhome_1
Specify the
			 ORACLE_SID variable for the AcmeBIPublisher database.
export ORACLE_SID=AcmeBIPublis
Execute the
			 ORACLE_HOME/bin/sqlplus script.
[oracle@vm bin]$ ./sqlplus '/ as sysdba'
Use the following
			 option to shutdown the Oracle database instance and exit:
SQL> shutdown immediate; SQL> exit
Specify the
			 ORACLE_SID variable for the Report Manager database instance (OCSDMDW).
export ORACLE_SID=ocsdmdw
Execute the
Use the following
