Edit the Offline Configuration
- Expand the Configuration Manager slider and click Configuration tools, Offline Configurations.
- In the Offline Config tab, select the offline configuration you want to edit from the table and click Edit.
In the
Edit
offline configuration dialog box, enter the description that you
want for this offline configuration. If you are logged into Oracle
Communications Session Delivery Manager as the Lawful Intercept (LI)
administrator user, you can enter the LI encryption password for the LI
configuration. Note that the LI encryption password parameter is not available
for the Enterprise Edge and Core plug-in at this time.
You cannot edit the global parameter configuration name. -
Click
OK.
Upon installation of Oracle Communications Session Delivery Manager, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.
