Configure a Fraud Detection and Prevention Device Registration
You can register Oracle Communications Session Delivery Manager (SDM) with a Fraud Detection and Prevention (FDP) device, so that the FDP device can send automatic Fraud Protection List (FPL) updates to SDM. You can later schedule these updates to be sent from SDM to southbound devices. The updates are then activated on these devices.
Register a Fraud Detection and Prevention Device
Register Oracle Communications Session Delivery Manager (SDM) with a Fraud Detection and Prevention (FDP) Device that you added. This action provides the FDP device with the information necessary for it to communicate with OCSDM.
- Expand the Fraud Protection Manager slider, and click Administration.
- In the Fraud detection devices page, select an FDP from the FDP table and click Register.
Re-register a Fraud Detection and Prevention Device
Use this task if you need to re-register a Fraud Detection and Prevention (FDP) device in Oracle Communications Session Delivery Manager (OCSDM).
For example, you need to re-register an FDP device after performing backup and restore operations for an OCSDM cluster, or when adding a new member node to an OCSDM cluster.
- In the Fraud detection devices page, select an FDP from the FDP table and click Unregister.
- Reselect the FDP and click Register.
View Fraud Detection and Prevention Device Registration Information
The Fraud Detection devices pane has a list of Fraud Detection and Prevention (FDP) devices that Oracle Communications Session Delivery Manager (SDM) has registered with to receive fraud updates.
Search Fraud Detection and Prevention Device Registrations
Refer to the Fraud Protection Manager Search Filters section for more information on filtering when you use a search criteria.
Re-synchronize Session Delivery Manager with Fraud Protection List Data
You can re-synchronize Oracle Communications Session Delivery Manager (SDM) so that SDM has all of the Fraud Protection List (FPL) data that is available.
- In the Fraud detection devices page, select a registered FDP from the FDP table and click Re-synch.
Unregister a Fraud Detection and Prevention Device
Unregister a Fraud Detection and Prevention (FDP) Device with Oracle Communications Session Delivery Manager (SDM) so that it does not receive automatic fraud updates.
- In the Fraud detection devices page, select a registered FDP device from the FDP table and click Unregister to unregister the FDP device.
- In the confirmation dialog box, click Yes to unregister the FDP registration so that this device no longer receives automatic fraud updates through SDM.
Register an unregistered Fraud Detection and Prevention (FDP) Device with Oracle Communications Session Delivery Manager (SDM) so that it can receive automatic fraud updates.
- In the Fraud detection devices page, select an unregistered FDP from the FDP table and click Register to register the FDP device with SDM again.
