Commit a Software Upgrade Work Order Manually
After an upgrade work order is executed, it must be committed to unlock the targeted devices that are associated with the upgrade work order. An upgrade work order is committed manually if the Auto commit check box is unchecked in the upgrade work order.
Only upgrade work
orders with a status of
Success,
Failed,
Aborted,
AbortFailed, or
CommitFailed can be
committed. When you commit an upgrade work order, a rollback is no longer
possible, all targeted devices associated with this work order are unlocked,
and this upgrade work order can no longer be modified. You must create a new
upgrade work order to implement new changes. Until the upgrade work order is
committed, you can stop it and perform a rollback to restore the original
software or bootloader version or original configuration settings.
- Expand the Device Manager slider and click .
- In the Work orders table, select the work order you want to commit and click Commit. A confirmation dialog box appears.
- In the confirmation dialog box, click Yes.
- Click Refresh to confirm the work order status changed from Success to Committed.
