Verify Your User Permissions to Apply Software and Bootloader Upgrades to Devices
The ability to apply software and bootloader upgrades on
targeted devices depends on the user permissions that you were assigned in
Security Manager and product plugin service features. You can do certain
operations when you are logged in as one of the following user types:
- LIAdministrators and administrators—You can create, modify, execute, delete and control a work order.
- provisioners—You can execute and control (start, abort, pause, resume, or commit) a work order.
- monitors—You can view work orders only.
Upon installation of Oracle Communications Session Delivery Manager, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.Note:
The Oracle Enterprise Session Border Controller does not support LIAdministrators.See the Configure Security Privileges for Session Delivery Products section in the Security chapter of the Oracle Communications Session Delivery Manager Administration Guide for more information.
