Generate a Template
- Expand the Configuration Manager slider, expand Configuration tools, and click Offline Configurations.
- In the Offline Config page, select the offline configuration row to use for this spreadsheet and click Generate Template.
- In your browser, a dialog box appears to either open or download the template file. Open the file, edit your spreadsheet as necessary, and save.
