PreviousNextJavaScript must be enabled to correctly display this content
View Codec and Transcoding Data
Codec data displayed by Oracle Communications Session Element Manager is available for supported C-series and D-Series Oracle Communications Border Controller (SBC) products.
SBCs need to have a transcoding NIU card for Codecs to work.
Codec Statistics
Pane
Realm name
The realm that corresponds with the listed codec.
Other
The codecs that are not matched with the standard,
well-known list of codecs.
