PreviousNextJavaScript must be enabled to correctly display this content
Export Detailed Device Information from Device Manager
You can also export detailed network function (NF) device information from the
Device details pane in Device Manager to your local system.
Expand the
Device Manager slider and click
Devices.
In the
Managed Devices pane, select the NF and click
Show details.
In the
Device Details pane, select only the tabs for which you want to save information and click
Save to File.
Only the tabs you select are saved. For example, if you select the
Hardware tab and next the
Software tab, the information for these tabs is saved only.
In the dialog box that appears, click
OK to download the information in the form of a CSV file to your system.
