Deploy a Device Cluster Using a Bulk Spreadsheet
Once you have generated a template and entered all of the required device information into the spreadsheet, you can deploy and manage the device cluster using the Device Manager, Bulk device deployment page.
The
Bulk device
deployment page contains two tabs:
- OC spreadsheet—Allows you to upload, add, modify, delete, and edit offline configuration template spreadsheets.
- Bulk Device Deployment—Allows you to create, schedule, edit, start, and delete bulk device deployment work orders. You can also view logs and work order statuses.
