Manage the Configuration Archive
Depending on your user privilege level, or privileges set for the User Group to which you belong, you can manage the configuration archive.
A configuration can exist on every node of a device cluster. When a configuration file is pulled from a device by a node, the file is sent to all cluster nodes. See Security Manager in the Oracle Communications Session Element Manager if you need to change your privileges to allow you to manage the configuration archive.
When R226 compliance is set as enabled upon installation, the OCSDM hides LI and SIPREC attributes, however, they still exist in the datadoc.Add a Backup Schedule
Use this task to schedule automatic configuration backup for a device or a device group to run once, daily, weekly, or monthly automatically. You can also configure a backup to run on demand. The following actions occur when you create a backup:
- A new directory is created for each device using its device name in the AcmePacket/ConfigBackups directory.
- An entry is added to the database for the configuration file.
- The set purge policy is applied.
Restore a Configuration Backup
The purge policy or existing configuration backups are not affected when a backup is restored for a device.
- On the Configuration Manager slider, select Configure archive, Archive configuration.
- Select a backed up configuration from the table, and click Restore.
- In the confirmation dialog, click Yes to restore the backed-up configuration.
Rename a Configuration
You can rename any backed up configuration file to make its name more meaningful. The actual file name on the system does not change and continues to adhere to the set file naming policy. This configuration name only appears within the context of Oracle Communications Session Element Manager.
Manage Purge Policies
You can select a purge policy for devices or device groups. You can customize the purge policy to define the number of backup configurations to store per device, to configure the purge schedule for devices or device groups, and to purge them immediately.
Create a Configuration Purge Policy
A purge policy must be selected and configured to have Oracle Communications Session Element Manager automatically delete configurations. You can also manage backed up configurations manually.
The Oracle Communications Session Element Manager plugin service provides the archive configuration name prefix for the archive configuration file name. The archived configuration files are kept in the Oracle Communications Session Delivery Manager server folder name ConfigBackups under the AcmePacket directory. The archived configuration file for each device uses the device IP address in the directory path.
Search the Archive for a Configuration
Use this task to search for a configuration in the configure archive for an existing configuration backup.
- Standard wild card
* and
? characters are
supported.
- * matches 0 or more characters.
- ? matches 1 character.
- Search filters containing wild card characters must be enclosed in double quotes: “fo*”.
- Search filters containing no wild card characters result in an exact match.
Wild card characters cannot be used outside of double quotation marks in combination with an exact match search.
“A*1” is a valid search filter.
“A*”* is not a valid search filter.
