Add a Bootloader Image to the Bootloader Image Archive Directory
The
bootloader image archive allows you to view, load, and delete all device
bootloader images maintained by the Oracle Communications Session Element
Manager.
Before you create your bootloader upgrade work order, you must upload
the correct bootloader image to the bootloader image archive on the server
directory:
AcmePacket/NNCArchive/BootImageArchive/<vendor-key>-<product-key>/<plugin-name-key>
Based on your Network Function (NF) type, the image is then uploaded
into one of the following sub-directories:
- Oracle-SessionDelivery/AcmeSD
- Oracle-enterprise/Enterprise
- Oracle-enterpriseext/EnterpriseExt
