Manage Upgrade Work Orders
Configure Downgrade Work Orders
Use the same tasks in the "Add Upgrade Work Orders" section if you need to do a downgrade across a group of targeted devices. The only difference is you must add a previous version of the software or bootloader image to the software image archive directory and bootloader image directory and select this software image later when you add the downgrade work order. The limitation is that some device downgrades may not supported. See your device product documentation for more information.
