Go to main content
47/47
Adding and Assigning Dashboards
Create an instance of the dashboard as a portlet. You do not need to perform this step if the portlet already exists.
In
OPERA Reporting and Analytics
, click
Admin
, click
Portal
, click
Portlets
, and then click
Portlets
Click
Add
Select
Dashboards
from the
Type
drop-down list.
Select the dashboard you want to add from the
URL
drop-down list.
Fill out the form, and then click
Save
Assign the dashboard to a role:
In
, click
Admin
, click
Portal
, click
Roles
, and then click
Portlets
Select the role, click
Configure
, and then click
Add
Select the dashboard portlet from the
Portlet
drop-down list.
Save
Members of the role can access the dashboard the next time they log into the system.
Scripting on this page enhances content navigation, but does not change the content in any way.
