Make sure the report you want to run has been published. OPERA Reporting and Analytics only shows reports for which you have access.
In the OPERA Reporting and Analytics side menu, click the link to go to the More Reports page. If you cannot find the link, contact your system administrator.
Click Analysis Reports, and then click a published report.
To run and view the analysis report, select or enter the report parameters, and then click OK.
To clear the report parameters, click Reset.
To print the analysis report, click Print, and then select a printable format.
To export the analysis report, click Export, and then select a file or data format.
