In OPERA Reporting and Analytics, click Admin, click Portal, click Roles, and then click Side Menus.
Select the role, and then click Configure.
Click Add.
Type a side menu title.
Type a side menu number.
The number determines the order in which the menu appears in the OPERA Reporting and Analytics navigation pane. For example, if you type 1, the menu is the first menu listed in the navigation pane on the OPERA Reporting and Analytics home page.
