Logon Name
User name for logging in to OPERA Reporting and Analytics.
Display Name
The name that appears on the user’s myPage. For example, enter the user’s first name.
Role
Select a default role for the user or select a role you created for your organization (for example, District Manager). The user inherits the system privileges associated with the role.
Active
Select to enable the user account.
Org Level
The level you select determines the level of access for the user. For example, a District Manager can access information for all the locations related to the level. To limit access to store-level information for a store manager, select the store from the drop-down list.
Revenue Center
Not applicable to hotels, do not use.
Chain Code
Restricts access to information at the hotel chain level, select all the hotel chains to which the user belongs.
