4. Annexure
4.1 Accounting Hand-off from External System to FCUBS
An external system can request for debit or credit to an account or GL in FCUBS through the interface.
The following major values will be passed as part of debit request for accounting hand-off:
Values
Description
Mandatory
MODULE
Module which is sending for accounting handoff
Yes
TRN_REF_NO
Transaction reference number for debit / credit
No
EVENT_SR_NO
Event serial no for Dr / Cr leg
Yes
EVENT
Event against which accounting to be posted
Yes
AC_BRANCH
Branch for accounting handoff
Yes
AC_NO
Account to which Debit / Credit to be done on accounting handoff
Yes
AC_CCY
Currency of the account
Yes
DRCR_IND
Account to be debited / credited on accounting handoff
Yes
AMOUNT_TAG
Amount tag against which accounting to be posted
Yes
LCY_AMOUNT
Local ccy amount for accounting handoff
Yes
ECAREFNO
ECA reference no generated for each request under a ECA create external reference no
Yes (Man­datory for ECA Debits only)
FCYAMT
Fcy amount for accounting hand­off, Mandatory, if Account cur­rency is Fcy.
No
EXCHRATE
If Ccy is Fcy, then exchange rate and Lcy amount tags are manda­tory.
No
BLOCKRELEASES­TATUS
Block release status to be set as F - Full debit; P – For partial debit (Only if partial release is allowed).
Yes
TRN_DT
Transaction date on which accounting to be posted. It’s a non mandatory field, if not provided, accounting would be posted to current system date.
No
VALUE_DT
Value date on which accounting to be posted. It’s a non mandatory field, if not provided, would be defaulted to current system date.
No
TXNNARRATIVE
Transaction narrative captured as part of request will be displayed in account statement.
No
The following values will be passed as part of accounting handoff for accounting posting:
Values
Description
Default value
Possible values
Mandatory
CHEQUE_MANDATORY
If debit to happen against an account based on the instru­ment no, then cheque mandatory to be Y.
N
Y / N
No
INSTRUMENTCODE
If cheque mandatory is Yes, then instru­ment code to be mandatory in the request. Based on that, the chq no would be updated to used in FLEXCUBE system.
Null
Valid instru­ment number
No
AVAILBALREQD
If balance checked to happen as part of ECA debit, this flag to be Y.
Y
Y / N
No
AVLINFO
Balance will be updated immediately / move to uncollected balance (for credit transaction alone) based on the value provided.
I - Imme­diate
I - Imme­diate-
V - On value Date
No
INTRADAYRELEASE
If Available info is I and intraday release is Y, then funds will be in Uncollected, to be cleared on intra­day batch run.
N
Y / N
No
ESCROW
If Escrow is set as Y, then on EAC credit, amount would be blocked, if it’s against a project account.
N
Y / N
No
CONSFORACCACTIVITY
To make the account undormant on ECA processing, then consider for account activity to be sent as Y in request.
Y
Y / N
No
CONSFORTRNOVER
To restrict the maxi­mum amount to be credited to an account, this flag to be sent as Y in the request.
N
Y / N
No
SWEEPREQD
If ECA debit is made more than requested amount and if sweep is Yes, then excess debit will be covered from cover accounts, if available balance isn't sufficient to cover excess debit.
N
Y / N
No
DEBIT_OVER­RIDE_TRACKING
If account is set for Debit override, if this tag has value B / O, then debit override will be displayed.
B
B/O
No
CREDIT_OVER­RIDE_TRACKING
If account is set for Credit override, if this tag has value B / O, then credit override will be displayed.
B
B/O
No
DONTSHOWINSTMT
If during reversal request of external entries, reversal entries to be excluded from account statement, then DONTSHOW­INSTMT should be Y.
N
Y/N
No
EVENTSRNOTOBEREVD
If during reversal request of external entries, event slr no to be reversed should be sent in request.
Null
Valid event slr no
Yes (for reversal request)
TRNCODE
If transaction code is sent as part of request, it will be stored in the ACT­B_ENTRIES_TRN­CODE_DETAILS table
Null
Transac­tion Code
No
SWIFT_CODE
If SWIFT_CODE is sent as part of request, then it will be displayed in the SWIFT account statement.
Null
Valid SWIFT code
No
ACTIONINDICATOR
Indicates the MIS is for Modification or New
Null
‘N’ or ‘M’
Yes
TAG61SUPPINFO
If the transaction is used for SWIFT mes­sage supplementary information will be send in this tag.
Null
USERREFNO
User reference num­ber used for Advice and SWIFT mes­sage.
Null
ISREVERSAL
Indicate the transac­tion from external process is for rever­sal or not.
Null
R or Null
BANKREFNO
Bank reference num­ber used for SWIFT message
Null
ADDLINFO
Additional informa­tion used for Advice and SWIFT mes­sage.
Null
Note
Transaction code is not mandatory for external entry hand-off.
The following values will be passed as part of accounting handoff for accounting posting for MIS:
Values
Description
Default value
BRNCD
Transaction Branch Code
Null
CALCMETH1
Calculation Method
Null
CCY
Currency
Null
COMPMIS1
Composite MIS code 1
Null
COMPMIS2
Composite MIS code 2
Null
COMPMIS3
Composite MIS code 3
Null
COMPMIS4
Composite MIS code 4
Null
COMPMIS5
Composite MIS code 5
Null
COMPMIS6
Composite MIS code 6
Null
COMPMIS7
Composite MIS code 7
Null
COMPMIS8
Composite MIS code 8
Null
COMPMIS9
Composite MIS code 9
Null
COMPMIS10
Composite MIS code 10
Null
COSTCD1
MIS Cost Code 1
Null
COSTCD2
MIS Cost Code 2
Null
COSTCD3
MIS Cost Code 3
Null
COSTCD4
MIS Cost Code 4
Null
COSTCD5
MIS Cost Code 5$
Null
CUSTOMER
Customer Number
Null
FUNDMIS1
Fund MIS Code 1
Null
FUNDMIS2
Fund MIS Code 2
Null
FUNDMIS3
Fund MIS Code 3
Null
FUNDMIS4
Fund MIS Code 4
Null
FUNDMIS5
Fund MIS Code 5
Null
FUNDMIS6
Fund MIS Code 6
Null
FUNDMIS7
Fund MIS Code 7
Null
FUNDMIS8
Fund MIS Code 8
Null
FUNDMIS9
Fund MIS Code 9
Null
FUNDMIS10
Fund MIS Code 10
Null
GRPREFNO
Group reference number to indicate the group of Trans­action doe which the MIS is applicable.
Null
MISGRP
MIS group
Null
MISGRPCOMP
Composite MIS group
Null
MISGRPFUN
Fund MIS group
Null
MISGRPTXN
Transaction MIS group
Null
MISHEAD
MIS head
Null
POOLCD
Pool Code
Null
PROCESSED­FLAG
MIS Processed Flag
Null
PRODUCT
Product code
Null
RATEFLG
Rate flag for MIS process­ing
Null
REFRATE
Ref rate for MIS
Null
REFRATECD
Ref rate code for MIS
Null
REFRATETYP
Ref rate type for MIS
Null
REFSPREAD
Ref spread
Null
REFXRATE
Ref exchange rate
Null
RELACC
Related account number
Null
RELET­ED_REFER­ENCE
Related reference number for MIS
Null
RGREL
Null
TXNMIS1
Transaction MIS code 1
Null
TXNMIS2
Transaction MIS code 2
Null
TXNMIS3
Transaction MIS code 3
Null
TXNMIS4
Transaction MIS code 4
Null
TXNMIS5
Transaction MIS code 5
Null
TXNMIS6
Transaction MIS code 6
Null
TXNMIS7
Transaction MIS code 7
Null
TXNMIS8
Transaction MIS code 8
Null
TXNMIS9
Transaction MIS code 9
Null
TXNMIS10
Transaction MIS code 10
Null
UNITREFNO
Reference number ,either account number or contract ref number base to the MIST type.
Null
UNITTYPE
Unit type ,to indicate Account MIS or contract MIS
Null
