Web GUI Changes in P-CZ3.2.0
The following information describes the new controls,
operations, and behavior of the Web GUI as of P-CZ3.2.0p1.
- Modification to "Latency Recommendation"—As of P-CZ3.2.0, a cache is not created in the browser. After upgrading from P-CZ3.2.0 GA to P-CZ3.2.0p1, you must manually clear the cache from your browser.
- The Branding bar has a slightly different look, however, the buttons and functionality remain the same.
- The Monitoring tab has been renamed Monitor and Trace.
- In the User menu, under admin, Sign Out has been renamed Logout.
- The Alarms Widget now provides a way to clear specific alarms.
- The Dashboard renders a better presentation of a maximized Widgets screen.
- The Policy Entries page no longer contains erroneous check boxes.
- All pages under the Configuration tab's Wizards page now have a Cancel button.
- The search functionality for all four options under the Monitor and Trace tab now include username=user.
