Supported Platforms
Platforms
- Netra X3-2 — Ships with the Operating System and software installed.
- Netra X5-2 — Ships with the Operating System and software installed.
- Netra X7-2 — You must install the Operating System and software from a USB memory device.
- Netra X8-2 — You must install the Operating System and software from a USB memory device.
- Go to My Oracle Support (MOS) at https://support.oracle.com to download the Operating System and software. See "Download Software from MOS."
- See the Software Installation information in the Oracle Enterprise Session Border Controller Installation and Platform Preparation Guide on https://docs.oracle.com/cd/E95619_01/index.htm for installation instructions.
Image and Boot Loader Files
The PCZ3.2.0 release uses the following image and boot
loader files:
- Image—nnPCZ320.bz
- Boot loader—nnPCZ320.boot
Cores and Threads
The following list shows the recommended number of cores and the expected number of SIP threads per platform. Note that the number of SIP threads may vary, depending on the configuration of your deployment.
- VM—Recommended 8 cores. Yields 3 SIP threads.
- Oracle Servers X3-2, X5-2, X7-2, and X8-2—Recommended 16 cores. Yields 9 SIP threads.
Memory
Oracle recommends at least 16G memory for all P-Cz3.2.0 deployments.
While the above presents standard recommendations, optimum vSBC resource sizing depends individual deployments. Oracle recommends that you work with consulting and/or sales teams to determine the best sizing for your deployment.
