Performing Order Maintenance
In this part: These topics describe how to update an existing order on the system:
         Introducing Order Maintenance describes how to access Order Maintenance to update an existing order and lists the features and restrictions of this program.
         Selecting an Order for Maintenance describes how to identify the order you wish to update or how to locate a particular order from a scan of orders.
         Work with Order Screen in Order Maintenance lists the fields you can update on the Work With Order screen, describes the results of your updates, and identifies any conditions or restrictions for updating each field.
         Changing Item Detail Line Information in Order Maintenance lists the fields you can update on the Work With Order Line screen, describes the results of your updates, and identifies any conditions or restrictions for updating each field for a specific item on the order.
         Adding an Item in Order Maintenance describes how to add an item to an existing order or how to reopen a closed or canceled order when you add an item.
         Increasing the Quantity Ordered in Order Maintenance describes how to increase or decrease the number of units ordered of an item and describes how to account for the item cancellation when you reduce the quantity ordered.
         Canceling an Item in Order Maintenance describes how to cancel a single, unshipped order detail line on an existing order and describes how to account for the item cancellation from the order.
         Canceling an Order through Order Maintenance describes how to cancel an entire order and describes how to account for the item cancellations resulting from the order cancellation.
         Returning and Exchanging Items in Order Maintenance describes how to perform an item return or exchange by first creating a return authorization, receiving the merchandise return, and crediting the customer.
         Enter Payment Methods Screen in Order Maintenance describes how to add a payment method to the order to release it from hold or how to change or delete payment information already defined for the order.
         Adding a Recipient Order in Order Maintenance describes how to enter an additional order to an existing order that will ship to a different address.
         Maintaining Quotes in Order Maintenance describes the updates you can apply to a pre-order quote before converting it to a regular order.
         Converting Quotes to Orders describes how to convert a pre-order quote to a regular order and the updates that the system performs.
         Order Line History In API allows you to receive order line history from an external system.
________________________________
