Reviewing Application Settings in the Jenasys Properties File
Purpose: Use the jenasys.properties file on the Order Management System application server to review base configuration settings for Order Management System, such as where the specific parts of the Order Management System application are installed and how they should run.
Important: The system updates the contents of this file during the installation process and you would typically not change the contents of this file.
Location of file: This file is normally saved on the application server at /domain/conf/jenasysproperties/, where domain is the WebLogic domain directory for Order Management System.
To review the file: When you review this file using a text editor, be careful not to change the settings in this file.
The settings in this file that you may wish to review for troubleshooting purposes are listed below
Setting |
Description |
LOG_DIR |
The directory on the Order Management System application server where the logs are stored. An example directory is properties\\serverconfig\\logging. |
The directory on the Order Management System application server where the system stores the server run-time data. An example setting is /domain/conf/OMSFiles, where domain is the WebLogic domain directory for Order Management System. |
XML_ CONVERSION and XML_CONVERSION_ADMIN |
Must be set to FORCE_SERVER in order to support Internet Explorer 9.0 or higher. This entry can be anywhere in the properties file. |
proxied.external.hosts |
Defines the necessary proxy information required for integrations with Order Management System. This setting is delivered with the application and should not be changed. |
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2020, Oracle and/or its affiliates. All rights reserved.
Legal Notices
