This document contains the general recommendations for customer’s using physical and virtualized environments to run its applications. It further clarifies Oracle Hospitality’s position with regard to running Oracle products in a virtualized environment, specifically that provided by VMware®.
Oracle Hospitality suggest varying degrees of server specifications upon which to run its Oracle Hospitality Fleet Management System platform. Oracle Hospitality keeps such configurations flexible to accommodate the customer’s needs in consideration of ship size, anticipated transactional volume, overall scope of applications involved in the provided solutions, budget, and preferred level of redundancy.
Audience
This document is intended for the technical personnel involved in installation process of the Fleet Management.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
| Date | Description of Change |
August 2019 |
March 2022 |
