6. Enabling SSL
The application is accessible only via https protocol; hence, after the deployment of the application, you need to enable SSL.
To enable SSL
- Login to console.
- $Domain_Home > Servers > Manage Servers > Configuration > General. The below screen is displayed.
![](../screens/SSL1.jpg)
- Check the ‘SSL Listen Port Enabled’ check box.
- Specify the port for ‘SSL Listen Port’.
Note
It is recommended to disable http protocol.
