10. Collateral Management
Centralized Asset Management or Collateral Management System (CMS) enables the user to record a new collateral, evaluate it, and re-evaluate the existing collateral.
A Collateral Management System is used to minimize the frauds which involve the same collateral being pledged for different Lease and re-evaluating existing collateral manually or connecting to the VIN Interface.
The Collateral Details screen is opened from the Servicing > Servicing > Collateral Management and contains the following tab:
10.1 Collateral Tab
Using the Collateral screen, you can record a new collateral, view the valuation of collateral, and re-evaluate the existing collateral.
The collateral details can also be defined in the collateral screen of Application Entry screen.
Note
If you are working on Usage or Rental based type of leased collaterals, then additional op­tions are available in the Collateral Management screen to define the asset usage details and additional sub tabs such as Usage Summary and Usage/Rental Charge Matrix sub tabs are available. For detailed information on the same, refer to Customer Service screen’s Collateral tab section.
Collateral tab displays the usage / rental history of an asset which is linked to all accounts including the currently mapped account. This can be identified in Asset Relation tab, and usage of the asset can be viewed in Usage Summary tab.
The system assigns collateral statuses and the following are the statuses:
To enter the Collateral Details
  1. On the application master screen, click Servicing > Servicing > Collateral Management > Collateral Details.
  2. In this section, you can perform any of the Basic Operations mentioned in Navigation chapter.
A brief description of the fields is given below:
Field:
Do this:
Type and Description section
Collateral Type
Select the collateral type.
Primary
Select the check box if this property is the primary collateral.
Asset ID
View the asset identification number.
Asset #
View the asset number which is automatically generated.
Asset Class
Select the asset Class.
Asset Type
Select the asset type.
Sub Type
Select the asset sub type.
Registration #
Enter the vehicle registration number.
Status
View the vehicle status.
Select Make and Model
Select the Make and Model number of asset from the drop down list. You can use the search option to select the details.
Year
Specify the year of the vehicle.
Estimated Life
Specify the estimated life of the asset.
Make
Specify the make of the vehicle.
Model
Specify the model of the vehicle.
Identification #
Specify the vehicle identification number.
Body
Specify the body of the vehicle.
Description
Specify the description of the asset.
Condition
Select the condition of the asset from drop-down list.
Lien Details
Lien Status
Select the type of Lien action.
Lien Event Dt
Select the lien event date from the calendar.
Second Lien Holder
Specify the name of second lien holder.
Comments
Specify additional details if any.
Lien Release Entity
Select the lien release entity from the drop-down list. The list displays the following values:
- Customer
- Producer
- Others
- Business
Note: If ‘Others’ is selected as the Lien Release Entity, ensure that the Entity Name and Address details are updated cor­rectly since the same is not auto-validated with the data main­tained in the system.
Entity Name
If you have selected the lien release entity as ‘Customer’ or ‘Producer’, system automatically filters entity name list with corresponding customer accounts or producer. Similarly, if the lien release entity is selected as ‘Business’ system displays the Business name if the asset is linked to Business account. Select the required entity name from the drop-down list.
If you have selected the lien release entity as ‘Others’ specify the entity name.
Address section
Country
Select the country.
County
Select the county.
Address #
Specify the address number.
Address Line 1
Specify the first address line.
Address Line 2
Specify the second address line.
Zip
Select the zip code.
Zip Extn
Specify the zip extension.
City
Specify the city.
State
Select the state.
Usage / Rental Details (Cycle)
The below Usage / Rental sections are displayed only if the current Collateral is either of type VEHICLE or HOUSEHOLD GOODS AND OTHER COLLATERAL and the billing is based on Lease Usage or Rental type.
For more information on how OFSLL handles Usage based leasing, refer to Appendix - Usage Based Leasing chapter and for Rental based leasing, refer to ‘Rental Agreement’ section in Application Entry chapter.
Usage / Rental Cycle
Select the frequency of billing the asset from the drop-down list and click on ‘Load Details’ button. If details are maintained for the selected billing frequency in Setup > Products > Asset Types > Usage/Rental Details screen, the same is auto popu­lated and can be modified in this screen.
Min Usage per cycle
View/specify the minimum usage value of the allowed range.
Max Usage per cycle
View/specify the maximum usage value of the allowed range.
Base Rental Amount
View the calculated Base Rental Amount populated from Rental Agreement tab. This field is applicable for Rental/Usage Rental agreement type.
Security Deposit
View the security deposit amount paid upfront for the term. This field is applicable for Rental/Usage Rental agreement type.
Discount %
View/specify the percentage of discount exempted from final billing.
Discount Amount
View the flat discount amount allowed upfront from the final billing. This field is applicable for Rental/Usage Rental agree­ment type.
Usage Rollover/ Advance
View/select the type of asset usage calculation as one of the following:
- ROLLOVER (remaining usage balance is carried forward to next cycle)
- NO-ROLLOVER (remaining usage balance is not carried for­ward)
- ROLLOVER AND ADVANCE (remaining usage balance is carried forward to next cycle + total usage limit for current cycle can be utilized upfront)
- ADVANCE (total usage limit for current cycle can be utilized upfront)
Note: For Rental based lease agreement, only non rollover usage method is applicable.
Reset Frequency
View/specify the reset frequency of the billing cycle. This field is enabled only for ROLLOVER type of asset usage billing.
Elastic Term Calc Method
View the system predicted term remaining to reach the asset usage life which is calculated by one of the following methods as per current usage pattern.
- ACTUAL - here the current details updated/received is treated as the final record for usage term calculation.
- AVERAGE - here the average of usage details received in previous cycles are considered for usage term calculation.
Excess Rent Collection Method
If you have selected the Agreement Type as USAGE RENTAL, view the Charge Matrix selected as one of the fol­lowing type to derive the Excess Rent Collection Method:
- USING USAGE MATRIX
- USING RENTAL MATRIX
Usage / Rental Calculation
Calc Method
View/select the calculation method as one of the following from the drop-down list.
- TIERED (billing is based on the defined Usage/Rental Charge Matrix). This is the default value for Rental/Usage Rental agreement type.
- NON-TIERED (system automatically chooses the applicable slab based on the final usage value)
Usage / Rental Receipt
View/select the Usage / Rental details as one of the following from the drop-down list.
- INCREMENTAL (Details updated/received is considered as incremental record and is updated as new record in Servicing > Collateral > Usage History section without modifying exist­ing record)
- ACTUAL (Details updated/received is considered as latest record and is updated in Servicing > Collateral > Usage His­tory section with Active/ current status as ‘Y’). This is the default value for Rental/Usage Rental agreement type.
Usage Details
The details maintained in this section is used to calculate ‘EXCESS USAGE FEE’ in pay­off quote and termination transactions.
Start
View/specify the start unit of asset usage.
Base
View/specify the base units.
Extra
View/specify the extra usage units.
Total
View/specify the total usage units.
Vacation Ownership Details
Billling
Check this box to indicate if the asset is considered for billing.
Due Amt Account Type
Select one of the following account type from the drop-down list to indicate on which account this asset is to be considered for billing.
- Current Account
- Linked Account
- Master Account
Note: If ‘Billing’ option is checked and the Due Amt Account Type is selected as Current/Linked/Master Account, then the billing batch job posts the transactions based on Asset Billing Rate setup in Current account / Linked Account of current Account / Master Account of current Account respectively.
Trade Eligible
This check box is selected by default and indicates that the asset is eligible for trade.
If checked (Trade Eligible = Y) then Asset Status is marked as INACTIVE during Trade. If unchecked (Trade Eligible = N) Asset status is marked as ACTIVE.
Consolidate Points at Master
Check this box to indicate that point can be consolidated at master account level. Refer to ‘Consolidate Points at Master’ section for more details.
Points Consolidation Type
Select the type of points consolidation option from drop-down list. This field is used to identify the assets at Associated accounts to consolidate the points.
Custom Fields - This section displays the custom User Defined Fields if enabled in Setup and if configured, populates specific business computation values.
  1. Perform any of the Basic Actions mentioned in Navigation chapter.
  2. Click Submit.
If ‘Consolidate Points at Master’ option is checked, system consolidates the asset level points at Master Account of the associated account provided the following conditions are satisfied:
Points consolidation is done in following scenarios:
To ‘Consolidate Points at Master’, following validations and update options are provided:
10.1.1 Valuations Sub Tab
The Valuation sub section contains information about the value of the asset. The Values section enables you enter the value of the asset. The Addons sub tab records information about any add ons associated with the collateral.
To complete the Valuations section
  1. Click Valuations section.
Field:
Do this:
Valuations section
Current
Select if this is the current valuation.
Valuation Dt
Specify the valuation date.
Source
Select the valuation source.
Edition
Specify the valuation edition.
Supplement
Specify the valuation supplement.
Total Value =
View the total value.
Wholesale Base
Specify the wholesale value.
Usage
Specify the usage value; that is, the monetary effect that cur­rent mileage has on the value of vehicle.
Retail Base
Specify the retail value.
Addons +
View the add-ons value.
Usage Value +
Specify the usage. This pertains to Lease and usually is entered as the current mileage on vehicle.
  2. In the Addons section, you can perform any of the Basic Operations mentioned in Navigation chapter. You need to specify all the field values for every asset’s add-ons and attributes on the application.
  3. A brief description of the fields is given below::
    Field:
    Do this:
    Addons/Attributes
    Select the add-on/attribute.
    Value
    Specify the value of the attribute.
    Amt
    Specify the add-on amount.
  4. Perform any of the Basic Actions mentioned in Navigation chapter.
10.1.2 Tracking Sub Tab
The Tracking sub screen enables you to record further information associated with the collateral. What items you choose to track are setup during implementation.
To track attributes for the collateral
  1. Click the Tracking sub tab.
  2. In the Tracking Items section, click Load Details.
  3. In the Tracking Items section, you can perform any of the Basic Operations mentioned in Navigation chapter.
Field:
Do this:
Tracking Item
View the tracking type
Disposition
Select the disposition.
Start Dt
Specify the tracking start date.
End Dt
Specify the tracking end date.
Followup Dt
Specify the next follow-up date.
Enabled
Select to track the information from start date in the Start Dt field.
Comment
Specify any comments regarding the tracking item.
  1. Complete the Tracking Item Details section by entering information about a parameter in the corresponding the Value field.
  2. Perform any of the Basic Actions mentioned in Navigation chapter.
10.1.3 Vacation Ownership sub tab
In the Vacation Ownership sub tab you can capture and maintain ‘Timeshare’ specific collateral details of an account. This tab is displayed only for ‘Home’ collateral and allows to maintain only one records for the selected account.
For detailed information of the fields in this sub tab, refer to ‘Vacation Ownership tab’ section in Customer Service > Collateral > Home tab.
10.1.4 Status History Sub Tab
The Status History sub tab enables you to view the asset history of association with accounts.
To view the Status History
  1. Click the Status History sub tab.
  2. In the Status History section, view the following information:
    Field:
    Do this:
    Account #
    View the account number.
    Status
    View the status of asset.
    Lien Status
    View lien status of the asset.
    Line Event Date
    View lien event date of the asset.
    Data Change Sta­tus
    View the data change status of the asset.
    Data Change Date
    View the data change date of the asset.
    Comments
    View comments of the asset if any.
10.1.5 Asset Relation Sub Tab
The Asset Relation sub tab enables you to view the asset relationship.
To view the Asset Relation
  1. Click the Asset Relation sub tab.
  2. In the Asset Relation section, view the following information:
    Field:
    Do this:
    Account #
    Asset #
    View the asset number.
    Account Status
    View the Account status.
    Current Ind
    Indicates that this is the current asset.
    Primary Ind
    Indicates that this asset is the primary.
10.1.6 Audit Sub Tab
The Audit sub tab enables you to view the asset relationship.
To view the Audit
  1. Click the Audit sub tab
  2. In the Audit section, view the following information:
    Field:
    Do this:
    Account Id
    View the account identification number.
    Asset Id
    Column Name
    View the column name.
    New Value
    View the new value.
    Old Value
    View the old value.
    Changed By
    View the person name who changed the details.
    Changed Date
    View the date on when the details are changed.
10.1.7 Usage Summary
The Usage Summary sub tab gives you a summary of units charged for asset Usage/Rental which is derived based Usage/Rental Charge Matrix for Usage/Rental based lease account.
The incoming data of asset usage details are classified into the chargeable buckets of Base, Cycle, and Life and based on the defined amount, the total units are charged. Here each record indicates chargeable units for each billing cycle. For detailed information, refer to Usage Summary section.
10.1.8 Renting History
The Renting History sub tab gives you a summary of total charges levied/collected on an asset during its life when it has been rented/linked to different accounts.
The incoming data of asset usage/rental details are classified into the chargeable buckets of Base, Cycle, and Life and based on the defined amount and term, the total rental amount is calculated. Each record indicates total rental amount charged on individual account.
The calculated rental amount is only displayed and is posted on the account only after posting Account Close Monetary transaction on the account. For more information on how OFSLL handles Rental based leasing, refer to ‘Rental Agreement’ section in Lease Origination User Guide.
In the Renting History section, you can select ‘Show All’ check box to display all the rental calculation records for the selected collateral. A brief description of fields is given below:
In this field:
View this:
Account #
View the lease rental account number to which the asset is linked.
Agreement Dt
View the account funded date.
Agreement Terms
View the actual contract term converted into days (i.e. Maturity Date minus Contract date).
Termination Dt
View the account closure date.
Actual Terms
View the number of days between account funded date and account close date.
Usage Start
View the starting units from when billing is done.
Usage End
View the ‘Current Usage’ value at the time of termination.
Excess Usage
View the difference of total usage from usage start value.
Base Amount Charged
View the minimum rental amount charged.
Excess Amount Charged
View the excess amount charged which is calculated based on the difference of final usage value from agreed usage.
Total Amount Charged
View the total of Paid / Terminated amount from all bal­ances after lease rental account is closed.
10.1.9 Usage Charge Matrix sub tab
The Usage Charge Matrix sub tab displays the different chargeable slabs defined based on the combination of Billing Cycle and Charge Type. The details maintained here are used for billing calculation based on a particular asset usage.
The information in this tab is auto-populated based on details maintained in Asset Type setup. For more information about field details, refer to ‘Usage Charge Matrix’ section in Setup guides.
10.1.10 Rental Charge Matrix sub tab
The Rental Charge Matrix sub tab displays the different chargeable slabs defined based on the combination of Billing Cycle, Rental Duration, Charge Per Cycle and Charge Type. The details maintained here are used for billing calculation based on a particular asset usage.
The information in this tab is auto-populated based on details maintained in Asset Type setup. For more information about field details, refer to ‘Rental Charge Matrix’ section in Setup guides.
10.2 Search Tab
A Search screen is available on the Collateral Management System to help locate information such as an asset type, asset number, identification number, asset status, make, model, and year. This is the information that is used on the Collateral screen.
To search for a Collateral details
  1. On the Oracle Financial Services Lending and Leasing Application home screen, click Servicing > Servicing > Collateral Management > Search.
  2. The Collateral Management screen’s Search screen appears.
  3. In the Search Criteria section, use the Comparison Operator and Value columns to enter the search criteria you want to use to locate a collateral.
  4. Click Search. The system displays result of the search in Results screen.
  5. On the Results screen, select the collateral you want to load and click Submit. The system loads the collateral details on the Collateral Details screen.
