The Balance Types link displays the various types of balance types computed for each producer (or “dealer”) set up in the WFP module. The balances defined in the Balance Types section are fixed, system defined, and set up during WFP installation. You cannot add or modify any balance types. However, you can choose not to use a balance type by clearing its Enabled check box.
To view the Balance Types link
On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > WFP > Balances
Note
If you choose, use Search Criteria to limit the display of records.
In this field: |
View this: |
Type |
The transaction type. |
Code |
The balance code. |
Description |
The description. |
Level |
The balance level. This indicates whether the balance is computed at Producer, Credit line, or unit level. |
Enabled |
Select to enable the balance types. When this check box is clear, Oracle Financial Services Lending and Leasing will not compute this balance from that date on for all new producers, credit lines, or units. |
Note
The balance types Principal balance and Interest should be enabled at the unit level.
