The Contract link allows you to define the terms and conditions of your contracts. Contracts can be defined according to company, branch, and type of unit. You can add new contracts and modify the existing ones.
Oracle Financial Services Lending and Leasing selects which instrument to offer based on whether:
To use the Contract link
On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > WFP > Contracts
In the Instrument section, select the record you want to work with and click Show in the Details column.
In this field: |
Do this: |
Name |
Enter the unique name of the instrument (required). |
Description |
Enter the instrument description. This entry should briefly describe the instrument (required). |
Company |
Select the company for which the instrument is applicable (required). |
Branch |
Select the branch of the company for which the instrument is applicable (optional). |
Start Date |
Enter the start date. This is the date after which the instrument is in use and is available on the Wholesale Floor Planning Maintenance form (required). |
End Date |
Enter the end date after which the instrument is invalid and unavailable on the Wholesale Floor Planning Maintenance form. While this field can be empty, it cannot be less than the current date or start date (required). A blank field indicates no end date (optional). |
Enabled |
Select to enable the contract instrument. |
Unit |
Select the unit type (required). This field links the policies to contracts. There should be at least one enabled contract for every unique unit type (required). |
Start Basis |
Select the accrual start date basis. This indicates the date from which the interest rate would be calculated. For example, a start basis that equals the payment date implies that the interest rate calculation starts with the first payment date (required). |
Payment Tolerance Amount |
Enter the payment tolerance amount. This defines the acceptable shortfall in the monthly payment in dollars for which no penalty would be imposed (required). |
Writeoff Tolerance Amount |
Enter the writeoff tolerance amount. This is the tolerance acceptable while a unit gets paid off. The unit will be considered paid even if payment is falling short of actual due by this amount (required). |
Pmt Tolerance% |
Enter the payment tolerance percent. This defines the acceptable percent of the monthly payment due which no penalty would be imposed. For example, the tolerance can be set for 95 percent of payment due (required). |
Late Charge Grace days |
Enter the late charge grace days. This is the number of days after the payment due date during which no late fee would be charged (required). |
# Rate Changes/Year |
Enter the number of rate changes in a year. This is the maximum number of times the rate can be changed in a year for a unit. Note: The number of rate changes in a year cannot exceed the number of rate changes for the life of the contact (required). |
Max Rate Increase Year |
Enter the maximum rate increase in a year. This is the ceiling limit for rate increases in a year (required). |
Max Rate Decrease Year |
Enter the maximum rate decrease in a year. This is the floor limit for rate decreases in a year (required). |
Accrual Base Days |
Select the accrual base days. This is the number of days the instrument assumes in a year for interest computation: 360, 365, or 366. If the accrual base is selected as 365, the interest computation would be based on actual days (365) and the base would be 365. However, in this case, if the year happens to be a leap year and the actual day’s computation includes the month of February, then the additional day of leap year is not considered (required). |
Accrual Start Days |
Enter the accrual start days. This is the number of days after which interest accrual starts once the instrument is in use (required). |
Refund Tolerance Amount |
Enter the refund tolerance amount. If the refund due to the producer is more than this, the tolerance amount is refunded. Note: You cannot complete this field if the Refund Allowed box is selected (required). |
Dlq Grace Days |
Enter the delinquency grace days. This is the number of days after the payment due date during which the account will not be considered delinquent (required). |
# Rate Change Life |
Enter the number or rate changes in life. This is the maximum number of times the rate can be changed during the life of the contract (required). |
Max Rate Increase Life |
Enter the maximum rate increase in life of loan. This is the ceiling limit for rate increase during the entire life of the contract (required). |
Max Rate Decrease Life |
Enter the maximum rate decrease in life. This is the floor limit for rate decrease during the entire life of the contract (required). |
Refund Allowed |
If selected, this check box indicates this instrument allows a refund in case the producer pays in excess of what is due (required). |
The Instrument Balance Types section allows you to define the balance type for the selected instrument at the producer, credit line, or unit level.
In this field: |
Do this: |
Select |
If selected, indicates that this is the current record. |
Balance Type |
Select the balance type (required). |
Level |
View the level indicator. This entry is based on the selected Balance Type and is non-editable (required). |
Include Monthly Due ? |
Select to compute the minimum monthly payment. |
