The Fees link allows you to define the method of computing the various producer, credit line, and unit level fees. You can define different fee calculations for a state, producer, and credit line.
Note
The Fee Rules section on the Fees link displays all the system defined balance types, even those disabled on the Balance Types screen. This is necessary for Oracle Financial Services Lending and Leasing to retain the fee rules associated with the balance type in case any are already associated with any existing units.
To use the Fees link
On the Oracle Financial Services Lending and Leasing home screen, click Setup > Setup > WFP > Fees.
Note
If you choose, use Search Criteria to limit the display of instrument records.
In this field: |
View this: |
Fee |
The system defined fee types applicable for WFP (display only). |
Description |
The balance description of the fee type (display only). |
Level |
View the balance type level at which a fee is applicable: Producer, CreditLine, or Unit (display only). |
Note the following:
In this field: |
Do this: |
State |
Select state initials (required). |
Producer #: Name |
Select the producer (optional). |
Credit Line |
Select the credit line (optional). |
Start Date |
Start the date from when the fee rule is applicable (required). |
End Date |
Start the date till which the fee rule is applicable. A blank field indicates no end date (optional). |
Enabled |
Select to enable this fee rule. |
Calculation Method |
Select the calculation method. If the calculation method is FLAT, then Fee% field should have the value 0.0 and the Fee Amount - Maximum field would have the same value as that in the Fee Amount - Minimum field. Oracle Financial Services Lending and Leasing uses the Fee Amount - Minimum field for fee calculation (required). |
Fee% |
Enter the fee percentage (required). |
Fee Amount Minimum |
Enter the minimum fee amount that would be charged to the producer (required). |
Fee Amount Maximum |
Enter the maximum fee amount that would be charged to the producer (required). |
FLEXCUBE WFP supports the following types of fees and calculation methods:
Description |
Level |
Calculation Methods supported |
Non Sufficient Fees |
Producer |
Flat |
Producer Annual Fees |
Producer |
Flat |
Credit Line Audit Fees |
Credit Line |
Flat |
Late Charge |
Unit |
Flat Percentage of Payment Due Percentage of Balance Payment Unit Charge |
Unit Service Fees |
Unit |
Flat |
Unit Other Fees |
Unit |
Flat |
