The Reports master tab in Oracle Financial Services Lending and Leasing allow you to select a report in the Reports section, then values you want to use to generate the report in Report Parameters section and generate a report using that information.
This servicing report lists monetary transactions by GL post date for leases.
Parameters:
Example of the Amortized Txns Log By GL Post Dt - Lease report
This report lists monetary transactions by GL post date for lines of credit.
Parameters:
Example of the Amortized Txns Log By GL Post Dt - Line report
This servicing report lists monetary transactions by GL post date for loans.
Parameters:
Example of the Amortized Txns Log By GL Post Dt - Loan report
This servicing report lists general ledger postings is available for loans, lines of credit, and leases.
Parameters:
Example of the GL Posting Log report
Parameters:
Example of the Monetary Txns Log By GL Post Dt - Lease report
This servicing report lists monetary transactions by GL post date for lines of credit.
Parameters:
Example of the Monetary Txns Log By GL Post Dt - Line report
To generate the Payment Allocations Log by GL Post Dt - Loan report
Example of the Monetary Txns Log By GL Post Dt - Loan report
This servicing report lists payment allocations sorted by GL post date for leases.
Parameters:
Example of Payment Allocations Log - Lease report
This servicing report lists payment allocations sorted by GL post date for lines of credit.
Parameters:
Example of Payment Allocations Log - Line report
This servicing report lists payment allocations sorted by GL post date for loans.
Parameters:
Example of Payment Allocations Log - Loan report
Parameters:
Example of the Pool Txns Log By GL Post DT report
This servicing report lists producer monetary transactions sorted by GL post date for loans.
Parameters:
Example of the Producer Monetary Txns Log By GL Post DT report
The Wholesale Floor Plan command enables you to create the following reports:
The WFP Audit Verification report lists the active units under each credit line for a producer. This report can be printed and the hard copy can be used for an actual floor audit to verify that units are available on producer’s floor.
To generate the WFP Audit Verification Report
Example of the WFP Audit Verification report
The WFP Credit Lines and Outstanding Summary report lists the credit lines for each producer and outstanding balance.
To generate the WFP Credit Lines and Outstanding Summary report
Example of the Credit Lines and Outstanding Summary report
The WFP Inventory Finance Statement report displays in detail the unit level principal, interest and service fees ( totals of which are mentioned in Statement Summary report).
To generate the WFP Inventory Finance Statement report
Example of the WFP Inventory Finance Statement report
The WFP Inventory Financing Statement Summary report displays current and past due principal, interest, and unit services fees, along with the other fees applicable at credit line and producer level. The report is as current as of a statement date and does not display the latest dues.
To generate the WFP Inventory Financing Statement Summary report
Example of the WFP Inventory Financing Statement Summary report
The WFP Open Portfolio Duplicate ID report identifies and lists multiple occurrences of the vehicle identification number within retail and wholesale accounts. A identification number appears in the report only if multiple occurrences exist. The vehicle identification number is the only criteria used for checking duplicates, irrespective of the model and make.
To generate the WFP Open Portfolio Duplicate ID report
Example of the WFP Open Portfolio Duplicate ID report
The WFP Outstanding Summary by Branch report provides summary of the outstanding amount due from producers.
To generate the WFP Outstanding Summary by Branch report
Example of the WFP Outstanding Summary by Branch report
The WFP Unit Balances/Pay-off Quote Report lists units under each credit line and displays interest owed as well as current principal balance for the unit. The report also displays the payoff quote as of when report was created. Oracle Financial Services Lending and Leasing summarizes the data for each credit line to display the credit line level total. In turn, Oracle Financial Services Lending and Leasing also summarizes all the credit line level data to arrive at the producer level balance.
To generate the WFP Unit Balances / Pay-off Quote Report
Example of the WFP Unit Balances / Pay-off Quote report
