Data that is uploaded into the Object Storage is loaded into the application staging tables. The Scheduler Service allows you to process data from the Object Storage to staging tables by scheduling and running batches.
The following tasks are performed in the Scheduler Service to process data:
· Process data once, daily (once in a day), weekly, or a customized schedule
· Schedule a date and time for each batch to run
· Re-run, re-start, and monitor the batch
To process data files into the staging tables, you must run the batch using the Schedule Batch feature in the Scheduler Service. For more information, see Scheduler Service.
NOTE:
· In the Scheduler Batch feature, you must select the ready-to-use batch name (AMLDataload) to run the batch.
· If you are loading external batches (CS and KYC) from the Investigation Hub, you must run the following batches in order:
· 1. DataLoadCS
· 2. DataLoadKYC
ATTENTION:
If your firm has implemented multiple products, you are not required to load data separately for each product. You must run the data load batch once for all products.
