Scenario Pipelines enable you to create scenarios by defining behavior that consists of events in a predetermined order. You can use these events to thread multiple data streams together. Scenarios are used to identify behaviors of interest, potentially problematic behaviors with respect to securities, regulations, and possible money-laundering activities.
These scenarios consider whether the geographical location or entities involved warrant enhanced scrutiny; monitor activity between accounts, customers, correspondents, and other entities to reveal relationships that could indicate efforts to launder funds; address sudden, significant changes in transaction activity that could indicate money laundering or fraud; and detect other types of activities that are considered potentially suspicious or indicative of money laundering.
As part of configuring a scenario pipeline, parameters are defined, which are then tuned in the Threshold Manager.
FCCM TM Cloud Service comes with the following ready-to-use, pre-configured scenario pipelines:
· Structuring - Potential Structuring in Cash and Equivalents - Customer Focus
· Structuring - Deposits Withdrawals of Mixed Monetary Instruments - Customer Focus
· Structuring - Avoidance of Reporting Thresholds - Account Focus
· Structuring - Avoidance of Reporting Thresholds - Customer Focus
· Structuring - Avoidance of Reporting Thresholds - External Entity Focus
· Transactions in Round Amounts - Account Focus
· Rapid Movement of Funds All Activity - Account Focus
· Escalation in Inactive Account - Account Focus
· CIB Significant Change From Previous Average Activity - Account Focus
· CIB Significant Change From Previous Peak Activity - Account Focus
· CIB High Risk Geography Activity - Account Focus
· CIB Foreign Activity - Account Focus
· CIB Product Utilization Shift - Account Focus
· Transactions in Round Amounts EFT - External Entity Focus
· Transactions in Round Amounts MI - External Entity Focus
· Focal High Risk Entity - Account Focus
· Focal High Risk Entity - Customer Focus
· Focal High Risk Entity - External Entity Focus
· Patterns of Funds Transfers Between Internal Accounts and Customers - Customer Focus
· Patterns of Funds Transfers Between Customers and External Entities - Customer Focus
· High Risk Counter Party - Account Focus
· High Risk Counter Party - Customer Focus
· High Risk Counter Party - External Entity Focus
· High Risk Geography - Account Focus
· High Risk Geography - External Entity Focus
· Large Depreciation of Account Value - Account Focus
· Large Reportable Transactions - External Entity Focus
· Large Reportable Transaction - Customer Focus
· Possible Currency Transaction Report - Customer Focus
· Possible Currency Transaction Report - External Entity Focus
· Hub and Spoke - Customer Focus
· Hub and Spoke - External Entity Focus
· Rapid Movement of Funds - Customer Focus
· Rapid Loading and Redemption of Stored Value Cards - Account Focus
· Rapid Loading and Redemption of Stored Value Cards - Customer Focus
· Anomalies in ATM Bank Card Foreign Transactions – Account Focus
· Anomalies in ATM Bank Card Foreign Transactions – Customer Focus
· Anomalies in ATM, Bank Card: Excessive Withdrawals - Account Focus
· Anomalies in ATM, Bank Card: Excessive Withdrawals - Customer Focus
· Single or Multiple Cash Transactions - Large Significant Transactions - Customer Focus
· Early Payoff or Paydown of a Credit Product - Account Focus
· Early Payoff or Paydown of a Credit Product - Customer Focus
· Early Closure of Term Account - Account Focus
· Policies with Large Early Removal - Customer Focus
· Insurance Policies with Refunds - Customer Focus
For detailed information about these scenario pipelines, see the Technical Scenario Description.
Depending on the pipeline type, specific widgets are available in the widgets pane. The following table describes these widgets and the sequence in which the widgets can be placed from start to end in a scenario pipeline.
Scenario Pipeline – Widgets and Descriptions
Sequence |
Widget |
Name |
Description |
Precedence |
Additional Information |
1 |
High Level Dataset (HLD) |
Use this widget to add a High Level Dataset. Essentially, this is the data that is used to detect unusual or suspicious behavior. |
NA |
A scenario pipeline must always begin with an HLD widget. |
2 |
Episode |
Use this widget to add an Episode. Episodes allow you to generate events which meet specific criteria. For example, if the sum of consecutive transactions fall under the specified range, it is considered an episode. If the number of episodes crosses specified number of thresholds, an event will be generated. |
1 |
An episode is not mandatory in a scenario pipeline. |
3 |
Risk Indicator |
Use this widget to add a Risk Indicator. Risk indicators help determine the overall risk of transactions and parties and aid users working with events. |
1 |
4 |
Segment |
Use this widget to add a Segment. Segments allow you to set different values for meeting evaluations based on specified attributes. Using segments helps generate events based on applying different values to risk indicators and evaluations. |
3 |
A segment is not mandatory in a scenario pipeline, but a scenario pipeline can contain multiple segments that can either be connected in a sequential or parallel manner. |
5 |
Evaluation |
Use this widget to add an Evaluation. Evaluations are used to define conditions for the measures that are defined in the risk indicator. Evaluations perform logical comparisons against these conditions to generate events |
3,4 |
6 |
Create Event |
Use this widget to create an Event. An event is a record of one or more pattern matches in a detection run, which is a signal for further investigation. |
5 |
A scenario pipeline must always end with a Create Event widget. |
To add a high level dataset and begin a scenario pipeline, follow these steps:
1. Navigate to the Pipeline Designer page.
2. Click
on
the upper left corner. The list of pre-configured HLDs is displayed. FCCM TM Cloud Service comes with
the following pre-configured High Level Datasets (HLD).
· External Entity Transaction
· Transaction by Customer
· Transaction by Account
3. Drag and drop the required HLD to the designer pane.
4. Hover on the
HLD widget and click Edit
A dialog box is displayed.
5. Specify the required details.
6. Click Save
to
save the changes. The HLD is saved.
7. You can perform certain tasks that are common in all the widgets, such as edit, delete, filter, and so on. For more information, see Common Tasks.
You can add multiple conditions within the dataset to be considered by the scenario when detecting behaviors of interest. This can help improve the accuracy of your detection results and reduce false positives. For more information, see Adding Additional Threshold Conditions.
Risk Indicator is a measure used to indicate the overall risk involved in an activity. Relevant data is compared against a set of risk indicators to identify the early signals of increasing risk exposures in various areas of an enterprise. In this context "Risk" refers not only to derived risk values (geography, watchlist, entity, and so on) but also to certain behaviors that constitute risk relative to the activity being monitored. For example, the total transaction amount of wires involved in a hidden relationship represents a risk that can be measured based on applying configurable limits that are applicable to the scenario pipeline.
To create a risk indicator, follow these steps:
2. Drag and drop the Risk Indicator widget from the widgets pane to the designer pane.
3. Hover on the
Risk Indicator widget and click Edit
. The
Risk Indicators pane is displayed.
4. Click
on
the left-hand side. The Risk Indicators Available
pane is displayed with the list of risk indicators.
5. Click Add in the Risk Indicators Available pane. A new pane is displayed at the bottom of the page.
6. Provide the details as described in the following table:
Fields to Create Risk Indicator and their Descriptions
Field |
Description |
Risk Indicator |
Enter the risk indicator name. |
Method |
Select the method to obtain the risk indicator output. The available methods are Aggregation and Expression. |
7. Provide the details as described in the following table, if you have selected Aggregation method:
Fields to Create Risk Indicator and their Descriptions (Aggregation Method)
Field |
Description |
Aggregator |
Select an aggregator from the drop-down list. |
Attribute |
Select an attribute from the drop-down list. |
Group by |
Select a Group-by clause. |
Look Back |
Select the required lookback option and provide the required details. You can further configure the Look Back period for the risk indicator when building the expression. Important: When configuring the LookBack Period in the Expression Builder, you must use the keyword "lookbackperiod". |
Filter Attribute |
Select filter attribute. |
Filter Operator |
Select filter operator. |
Filter Value |
Select the required filter value option and provide the required details. |
8. Follow these steps if you have selected the Expression method:
a. Add an expression
by clicking the Add
. The Expression
Builder dialog box is displayed.
b. Select the Attribute, Runtime Parameters, and operators. The resulting condition is displayed in the Condition field.
9. Click Save to create the measure or Save & Attach to create and also attach the measures to the risk indicators used.
10. You can perform certain tasks that are common in all the widgets, such as edit, delete, filter, and so on. For more information, see Common Tasks.
You must attach the required risk indicator for it to take effect.
To attach a risk indicator, follow these steps:
3. Hover on the
. A dialog box is displayed.
4. Click
on
pane is displayed with a list of available risk indicators.
5. Click
corresponding
to the risk indicator that you want to attach. The selected risk indicator
is moved to the Risk Indicators Used pane.
6. Click Save
to
save the changes. The Risk Indicator is attached.
Only user-configured measures can be edited. You cannot edit pre-configured measures. To modify details of a risk indicator, follow these steps:
2. Select the Risk Indicator widget that you want to modify.
3. Hover on the
4. Click
on
pane is displayed with the list of available risk indicators.
5. Click the Risk indicator that you want to modify and click Edit.
6. Modify the required details.
7. Click Save. The Risk Indicator is modified.
Episodes are used by structuring scenarios to generate events which meet specific criteria, based on runtime parameters. For example, if the sum of consecutive transactions fall under the specified range, it is considered an episode. If the number of episodes crosses the specified threshold, then an event will be generated.
To create an episode, follow these steps:
2. Drag and drop the Episode widget from the widgets pane to the designer pane, after a High Level Dataset.
3. Hover on the
Episode widget and click Edit
. The Episode window displays
any existing conditions.
4. Select options from the drop-down lists to edit existing conditions.
5. Select options from the List of Conditions to add additional conditions for consideration by the scenario. Configure these conditions by selecting options from the drop-down lists.
6. Click Add + to add a new runtime parameter which can be used by the conditions.
§ Enter the name for the runtime parameter in the Name field.
§ Enter a description for the runtime parameter in the Description field.
§ Select a Datatype for the runtime parameter from the Datatype drop-down list.
§ Enter any default values for the runtime parameter.
§ Click OK to save the runtime parameter.
7. Click Save
to
save the changes.
8. You can perform certain tasks that are common in all the widgets, such as edit, delete, filter, and so on. For more information, see Common Tasks.
A segment enables you to segregate data based on defined conditions. For example, risk levels. A segment can be defined where both the effective risk of the focal entity and the risk of the associated activity determine if the behavior meets a High Risk, Medium Risk or Regular Risk definition. Risk indicator triggering levels can be set according to the segment. Using segments allows for generating events based on applying different values to risk indicators and evaluation based on how a party fits within a defined segment.
To create a segment, follow these steps:
2. Drag and drop the Segment widget from the widgets pane to the designer pane.
3. Hover on the
Segment widget and click
4. Enter the name for the Segment in the Name field.
5. Click Add
corresponding
to the Output pane to open the segment group.
You can add multiple groups and multiple conditions under each group.
6. Select the dataset or Risk Indicator you want to add conditions for.
7. Select a column and operator (=,>, <, <=, >=, <>, LIKE, and so on) to configure the conditions.
For example: (Effective Risk >= $Effective_Risk)
The following table describes the columns available.
Segment Column Definitions
Column |
Dataset |
Description |
Net Worth Amount |
Customer |
The net worth required for generating an event using this segment. |
Customer Age |
Customer |
The number of calendar days that an account has been opened. This is used to determine whether an account is new or seasoned. |
Customer Number |
Customer |
The number of customers required for generating this event. |
Effective Risk |
Customer |
The effective risk level specified for the conditional thresholds to decide which set of threshold values would be applied in event generation. |
From Party Credit Debit Indicator |
Transaction |
Identifier of whether this transaction represents credits to the account or debits from the sending account. |
From Party Identifier |
Transaction |
Identifier for the party sending the transaction. |
To Party Identifier |
Transaction |
Identifier for the party receiving the transaction. |
Party Identifier |
Transaction |
Identifier for this party as it appears on this transaction. This might be a financial institution identifier (for example, ABA number or BIC) or other standard industry identifier (such as, TIN or account number). |
Transaction Number |
Transaction |
Number of transactions to be considered or calculated as part of the logic. |
Transaction Amount |
Transaction |
Monetary value of the funds involved this transaction. |
Left Entity |
Transaction |
Originator of the transaction. |
Right Entity |
Transaction |
Beneficiary of the transaction. |
Both Party Internal Account Identifier |
Transaction |
Identifier of whether or not both parties involved in this transaction are internal accounts. |
Transaction |
Identifier of whether this transaction represents credits to the account or debits from this account. |
Activity Risk |
Transaction |
Activity risk level specified for the conditional thresholds to decide which set of threshold values is applied in event generation. |
Counterparty |
Transaction |
Counterparty associated with this transaction. |
Geography Risk |
Transaction |
Identifier of the level of risk associated with the geographic characteristics of this transaction. Firms have used account addresses and customer information (for example, citizenship) to determine the level of risk. |
Total_Debit_Amount |
Risk Indicator |
Aggregate amount of debit transactions involved required to trigger an event, expressed in base currency. |
Activity_Risk |
Risk Indicator |
Calculated on the transaction for each party based on the risk of the entity on the other side of the transaction as well as channel being used. |
Total_Credit_Count |
Risk Indicator |
Total number of credit transactions required to trigger an event. |
Total_Debit_Count |
Risk Indicator |
Count of debit transactions required to trigger an event. |
Distinct_Counterparties_ for_Incoming |
Risk Indicator |
Total number of distinct originators crediting money into the focal customer's accounts. |
Distinct_Counterparties_ for_Outgoing |
Risk Indicator |
Total number of distinct originators debiting money from the focal customer's accounts. |
Total_Credit_Amount |
Risk Indicator |
Aggregate amount of credit transactions involved required to trigger an event. |
8. Click Save
to
save the changes. The segment is created.
Evaluations are used to define conditions for the measures that are defined in the risk indicator. Evaluations perform logical comparisons against these conditions to generate events.
To create an evaluation, follow these steps:
2. Drag and drop the Evaluations widget from the widgets pane to the designer pane.
3. Hover on the
Evaluations widget and click Edit
4. Enter the name for the evaluation in the Name field.
5. Click Add + corresponding to the Output pane to open the evaluation group. You can add multiple groups and multiple conditions under each group. The values which display in the Output pane are typically thresholds which can be managed in the Threshold Editor. For more information on configuring a filter, see Configuring Filter.
6. Click Save
to
save the changes.
In Scenario Pipeline, the Create Event widget is the final part of the pipeline and is used to produce an event. An event is a record of one or more pattern matches in a detection run, which is a signal for further investigation. An event is also a unit of work in which a focus appears to have exhibited behavior of interest, along with the supporting information. A focus represents a business entity around which activity is reviewed and aggregated. For example customer, account or external entity. Events can be generated from a pattern matching specific source events, a sequence of events, trends, conditions, or context.
To create an event, follow these steps:
2. Drag and drop the Create Event widget from the widgets pane to the designer pane.
3. Hover on the
Create Event widget and click Edit
4. Verify the
details and click Save
to
save the changes.
The Create Event widget is created.
