14 Process Monitor
The Process Monitor is used to monitor the current stage of the Process for different instances. After integration with an Application, the workflow can be invoked. After invoking it goes through all the stages defined. Process Monitor shows all the stages finished, current stage and stages to come if any. Your user group should be mapped to the function role WFMACC (Workflow Monitor Access) to access the Process Monitor window.
This window displays all the Workflows which are invoked from the Application with details such as Entity Name, Entity ID, Process Name, Process Description, Execution Start Time, Last Execution Time, Last Updated By and Status.
Click to display the following sub menu for Run Pipeline:
·       Abort- to abort an ongoing Run Pipeline.
·       Resume- to resume a Run Pipeline
·       Re-run- to execute a Run Pipeline again irrespective of the previous execution status.
Using the Search grid, you can search for a specific Pipeline by providing a keyword from Process ID, Process Name or Process Description and clicking. Click  to reset the Search fields.
You can sort the Processes displayed in the Process Monitor window based on Entity Id, Entity Name, Process ID or Process Name. Click  to go to Process Modeller window.
