Compiling the TSM Library and Documentation
Read the documentation that corresponds to your application's target operating system.
| Operating System | Description | Location |
This file provides information on how to compile the TSM SDK for Android. | sdk/lib/README.android
This file provides information on how to compile the TSM SDK for iOS. | sdk/lib/README.ios
This file provides information on how to compile the TSM SDK for Linux. | sdk/lib/README
WARNING:
The OpenSSL library must be downloaded before proceeding with development.SDK Directories
SDK directories are shown below. Note that not all listed directories may be present (or supported) in the current release.
| Path | Description |
apps
SDK based applications |
apps/tsc_sip
Reference demonstration/development guide app (tsc_sip_client.c) |
docs
SDK Documentation |
docs/html
Authoritative API HTML-based documentation. Access via “.../html/index.html” after running `make doxygen`. |
extlib
External, optional libraries |
lib
SDK Library source – to be linked with the target application |
lib/android-ndk
Android Specific library instructions and precompiled libs |
lib/CSM
Tunneling Client State Machine |
lib/EIP
Embedded TCP/UDP/IP Stack |
lib/include
SDK API definitions |
lib/OSAA
Operating System Application Adaptation APIs |
lib/TAPI
Tunnel Data and Control APIs |
lib/TPL
Tunnel Control and Data Message Parsing Libraries |
tools
Development Tools |
tools/wireshark
TSCF protocol dissector |
Download and Compile OpenSSL
The default version of OpenSSL has been removed. Developers should download the desired version of OpenSSL and modify the build script to allow on-the-fly integration with the SDK.
Android Development
Use the following method when developing for Android.
