WAN Optimization Reporting Enhancements
7.1 enhances the existing WAN Optimization monitoring facilities with graphical reports to display key WANOp data over time. To view the reports, navigate to Monitor > WAN Optimization.
Different reports may be selected from the dropdown in the upper left-hand corner of the Report pane, and filtered using the criteria to the left of the graph. Available reports include:
- Kilobytes Saved (Egress/Ingress)
- Compression Ratio (Egress/Ingress)
- Deduplication Ratio (Egress/Ingress)
- Data Reduction Percentage (Egress/Ingress)
- Deduplication Cache Percentage (Hit/New)
- Deduplication Cache Count (Hit/New)
- Deduplication Cache Kilobytes (Hit/New)
For in-depth descriptions of the information provided in these reports, please see the WANOp Setup and Configuration Guide.
Users can zoom in to view a period of time in greater detail by dragging on the graph to select the timeframe of interest:
To zoom out to the original graph data, click the Zoom Reset button in the upper right corner of the pane.
Users may also view reports for archived databases by selecting the report they wish to view, then scrolling down to the Manage Database Archives pane and selecting an archived database from the dropdown. Changing reports after selecting an archived database will reset the report to the current database.
