Oracle Hardware Support
Oracle SD-WAN Release 2.5 incorporates the T5000 seamlessly into the entire family of appliances offered by Oracle. Basic Oracle SD-WAN Edge appliances platform capabilities are listed below.
Appliance Model |
Conduits |
WAN Ingress Paths |
WAN Egress Paths |
Flows |
Flows with TCP Termination |
T5000 |
128 |
576 |
576 |
256,000 |
16,000 |
T3000 |
128 |
576 |
576 |
256,000 |
16,000 |
T750 |
32 |
216 |
216 |
64,000 |
8,000 |
T730 |
16 |
72 |
72 |
64,000 |
4,000 |
T510 |
8 |
36 |
36 |
32, 000 |
500 |
Table 1
Table 1 provides a detailed view of the supported hardware maximum capabilities. The number of conduits can be used to derive the number of sites if used as an NCN or as a client in a meshed configuration. If any of the appliances are used as a client device, the hardware can still support the number of conduits defined, but will be dependent on the Oracle SD-WAN Edge architecture deployed. Table 1 is provided so users understand the conduits supported by all platforms in Edge release 2.5.
