Private Registration Server (7.3 GA P3)
Beginning in 7.3 GA P3, customers who do not wish to depend on the public Registration Server may host a Private Registration Server for use during the Easy 1st Install process. The private registration server may be deployed for access via an incumbent private intranet or for access via the public Internet, and may use either a static IP host or a DNS-resolvable Fully Qualified Domain Name (FQDN).
Once the Private Registration Server (PRS) is installed and operational, the high-level data flow for the Easy 1st Install process to complete properly is as follows:
- User provides the serial number for the site being deployed to the NCN
- The NCN uploads package to
the PRS
- Connectivity must exist to the PRS from the NCN management port IP
- The NCN pushes the client package to the PRS via HTTPS
- Once the client appliance
is powered on and has an IP address/gateway/DNS for the management port, the
following occurs:
- The client will
attempt to establish an HTTPS session via its management port to the PRS and
provide its serial number
- Once the serial number is validated via the HTTPS session, the PRS will provide a URL for the client to download the appliance package
- The client appliance will establish a second HTTPS session to retrieve the appliance package based on the validated serial number
- The client will
For detailed information on deploying and using a Private Registration Server, please see the Private Registration Server Installation and Deployment Guide.
