Availability Report
The Network availability report provides comprehensive data regarding uptime, goodtime, badtime, downtime and incidents per WAN link, conduit, and path. This data is available on a per site basis at the NCN and at any of the client sites. The client site report is based on that client's conduits and WAN links. Here is an example of a client site report:
The definition of availability report terms follows:
Term |
Definition |
Oracle SD-WAN Edge Object |
A path, conduit or WAN Link. |
Incidents |
A counter for the number of periods of downtime. |
Goodtime |
The total amount of time that an object has been in a good state. |
Badtime |
The total amount of time that an object has been in a bad state. |
Uptime |
The total amount of time that an object has been in a state that is greater than dead. |
Downtime |
The total amount of time that an object has been in a dead state. |
Table 3
The report displays up to 24 hours of data by default. Other display options are available including, 1 hour, 24 hours, 7 days, or “All Available Data.” To access this report, login into the web console and select Monitor –> Availability Reports from the pull-down menu.
