Next Steps in the Site Cloning Process
Sample Next Steps for the newly created client site called “ClonedSite:”
- Please review the configuration of your new Site ‘ClonedSite' to ensure all information is correct.
The following parameters may need to be modified:
- WAN Link Rates and other WAN Link settings
- Interface Groups, including VLANs
- Conduit Service configuration, including Rules and Classes
- Internet/Intranet Service configuration, including Rules
- Routes
- High Availability, if desired (no HA settings have been copied from the original site) Provision the Conduit Service for your new Site. Navigate to the desired WAN Link(s) at each of the following Sites and enable the new Conduit Service on the Service Properties tab, then use the Provisioning tab to allocate bandwidth as necessary:
- Fargo
- Add paths for all Conduits
connecting to your new Site.
Some helpful tips to make this process simpler:
- When setting the Service Properties for a Conduit Service, enabling Auto-gen Paths will automatically create paths to any other remote WAN Link used by the Conduit that also has path auto-generation enabled. This option is only available for public Internet WAN Links.
- If not utilizing path auto-generation or the necessary paths are between to private intranet WAN Links, navigate to the Paths tab of the Conduit to add paths manually. If a path is added with the Reverse Also option enabled, a second path with the same configuration will be created in the reverse direction.
More detailed information on the elements of these steps is available in the APN Configuration Editor User's Guide.
