Eligibility for IPsec Non-Conduit Routes
Prior to Edge R5.2, IPsec tunnel routes would remain in the route table even if the tunnel became unavailable.
Routing Table Example A
Using the Keepalive option under Connections > [Site Name] > IPsec Tunnels enhances such behavior so that the IPsec Non-Conduit Routes will now be considered ineligible when the IPsec tunnel is no longer available.
Routing Table Example B
