Enhanced Match Criteria for Rules
In support of the new Virtual Routing and Forwarding (VRF) feature set, Edge 5.0 has significantly enhanced the criteria for Rule matching. The VLAN ID and the newly introduced Routing Domain may be used as match criteria for Rules in addition to the previously supported match criteria.
- Routing Domain: You can now choose one of the available, configured Routing Domains from the drop-down menu when creating a new Rule.
Figure 1: Routing Domain Drop-Down Menu
- VLAN ID: You can now enter one of the configured VLAN IDs in the VLAN ID field when creating a new Rule.
Figure 2: VLAN ID Field
