256-Site Adaptive Private Networks
This feature is only supported for APNs in which Oracle SD-WAN Aware R1.0 GA P1 (or later) has been deployed. See APN Software R4.0 GA Release Notes for more details.In Oracle SD-WAN Edge Software R4.0, a feature has been added to enable a single T5000, configured as an NCN, to create up to 256 static conduits. This doubles the previously supported scale. This will, in the general case, enable a T5000 NCN to govern an Oracle SD-WAN Edge with up to 256 Client Sites.
The T5000 can now also support a greater number of WAN Paths and Flows. See the below table for details on supported capacity for each NCN-capable appliance model:
Appliance Model |
T750 |
T3000 |
T3010 |
T5000 (w/o Aware) |
T5000 (w/ Aware) |
Max Static Conduits |
32 |
128 |
128 |
128 |
256 |
Max Dynamic Conduits |
16 |
32 |
32 |
32 |
32 |
Max WAN Ingress Paths |
216 |
576 |
576 |
576 |
1152 |
Max WAN Egress Paths |
216 |
576 |
576 |
576 |
1152 |
Max Flows (TCP Term off) |
64,000 |
256,000 |
256,000 |
256,000 |
512,000 |
Max Flows (TCP term on) |
8,000 |
16,000 |
16,000 |
16,000 |
16,000 |
Max Public WAN Links |
8 |
8 |
8 |
8 |
8 |
Max Private WAN Links |
32 |
32 |
32 |
32 |
32 |
Configuration Editor
In Oracle SD-WAN Edge Software R4.0, the user will continue to be able to create and edit Oracle SD-WAN Edge configuration files from the NCN web interface via Manage Network -> Configuration Editor. However, the Oracle SD-WAN Edge Configuration Editor on the NCN will only support creating and editing Oracle SD-WAN Edge configuration files for APNs with up to 128 Client Sites. To scale past 128 Clients, the Oracle SD-WAN Edge configuration file must be managed from Oracle SD-WAN Aware.
