Configuring High Availability on VMWare ESXi For instructions on how to set up HA sites and configure HA properties, see "Configuring High Availability." After deploying a VM, create a standard vSwitch. Remove the Uplink1 by clicking on the X button. Create a new port group and add the vSwitch you created in Step 1. Attach Network Adapter 5 of the Active appliance to the vSwitch. Attach Network Adapter 5 of the Standby appliance to the vSwitch. Note:Make sure the Network Adapter attached to the Standby appliance matches the one attached to the Active appliance. From the editor tool, enable the Oracle SD-WAN Edge service. Create an HA interface group with the following configuration Ethernet Interfaces: 4 Bypass mode: Fail-to-Block Assign the virtual IP to the HA interface.
