Introduction to Oracle SD-WAN Edge 8.2.0.0.0
Oracle SD-WAN Edge is the new name for the previously named Talari APN product.
- Specifications of supported platforms, virtual machine resources, and hardware requirements
- Overview of new features and enhancements
- Summaries of known issues and limitations
Supported Appliances
Oracle SD-WAN Edge 8.2.0.0.0 supports appliances functioning as Network Control Nodes (NCNs) or Client Nodes.
- Physical Appliances: E50, T860, E100, E500, T3010, E1000, T5000, T5200, D2000, D6000
- Virtual Appliances: VT800, VT800-128, CT800, CT800-128.
The E50 appliance only functions as a Client Node.Physical Appliances Scaling
The following table details the network scale for each appliance model when running Oracle SD-WAN Edge 8.2.0.0.0.
| Appliance Model | Max Static Conduits | Max Dynamic Conduits | Max WAN Ingress Paths | Max WAN Egress Paths | Max Flows (TCP Term off) | Max Flows (TCP term on) | Max Public WAN Links | Max Private WAN Links |
| T860 | 32 | 16 | 216 | 216 | 64,000 | 8,000 | 8 | 32 |
| E50 | 8 | 4 | 36 | 36 | 32,000 | 500 | 3 | 32 |
| E100 | 32 | 16 | 216 | 216 | 64,000 | 8,000 | 8 | 32 |
| E500 | 32 | 16 | 216 | 216 | 64,000 | 16,000 | 8 | 32 |
| T3010 | 128 | 32 | 576 | 576 | 256,000 | 16,000 | 8 | 32 |
| E1000 | 200 | 32 | 1000 | 1000 | 256,000 | 16,000 | 8 | 32 |
| D2000 | 200 | 32 | 1000 | 1000 | 256,000 | 16,000 | 8 | 32 |
| T5000 | 256 | 32 | 1152 | 1152 | 512,000 | 16,000 | 8 | 32 |
| T5200 | 550 | 32 | 5500 | 5500 | 512,000 | 16,000 | 8 | 32 |
| D6000 | 550 | 32 | 5500 | 5500 | 512,000 | 16,000 | 8 | 32 |
CT800 Virtual Appliance Scaling
| Platform | Max Static Conduits | Max Dynamic Conduits | Max WAN Ingress Paths | Max WAN Egress Paths | Max Flows (TCP Term off) | Max Flows (TCP term on) | Max Public WAN Links | Max Private WAN Links |
| CT800 | 16 | 8 | 120 | 120 | 64,000 | 5,000 | 8 | 32 |
| CT800-128Foot 1 | 128 | 32 | 576 | 576 | 256,000 | 16,000 | 8 | 32 |
Footnote 1 CT800_128, supported as NCN.
VT800 Virtual Appliance Scaling
| Platform / Base Conduit | Max Static Conduits | Max Dynamic Conduits | Max WAN Ingress Paths | Max WAN Egress Paths | Max Flows (TCP Term off) | Max Flows (TCP term on) | Max Public WAN Links | Max Private WAN Links |
| VT800 | 32 | 16 | 216 | 216 | 64,000 | 1500 | 8 | 32 |
| VT800-128Foot 2 | 128 | 32 | 576 | 576 | 256,000 | 16,000 | 8 | 32 |
Footnote 2 VT800_128, supported as NCN.
Upgrade Information
Application Upgrade Paths
- 7.3
- 8.0
- 8.1
Upgrade Considerations
- When upgrading to this release, the auto-generated HTTPS SSL Certificate is regenerated with a stronger certificate. Refresh the browser after the new software version activation is completed.
- Ensure your SSH client is upgraded to a current, stable version before connecting to Oracle SD-WAN.
OS Compatibility
- OS 7.0.x (Oracle Enterprise Linux based OS for all supported devices with 8.2)
- OS 5.2 (Debian based OS - only provided for D2000 and D6000)
- OS 5.1 (Debian based OS)
See the Oracle SD-WAN OS 7.0 Release Notes and Upgrade Guide for more information.
Coproduct Support
- Oracle SD-WAN Aware 8.2.0.0.0
To deploy this version of Oracle SD-WAN Edge on your network, each appliance must be running a supported version. If an OS update is required, see the Oracle SD-WAN Edge OS Partition Update Guide for instructions.
