FAQ
Who Should Update to Oracle SD-WAN Edge OS 7.0?
Customers who would like to take advantage of the enhanced security and stability of Oracle Linux based Oracle SD-WAN Edge OS 7.0 and who are willing to run Oracle SD-WAN Edge 8.2 GA (or later) on their network. Please refer to Oracle SD-WAN Edge OS 7.0 Release Notes for more details.
Sometimes, depending on settings, the browser will cache the old security certificate and prevent the user from accepting a new one. Deleting the cache on the browser will resolve the issue and can be done by typing CTL + SFT + DEL.
OS Partition Failure – Next Steps?
On the rare occasion that the OS Partition Update process does not complete, please capture a diagnostics file and contact Support:
- SSH into the appliance.
- Issue the tcon command to acquire the console.
- Issue the diagnostics command from the console and wait for process to complete.
After the diagnostics file is created, you will be asked if you would like to automatically send the file to Support via FTP. This is optional.
