Introduction to SD-WAN OS 7.0
The Oracle SD-WAN Edge software package sits on top of the SD-WAN OS on all Oracle SD-WAN Appliances. An OS Partition Image is used to update the OS image on an Oracle SD-WAN Appliance. For instructions on how to install an OS Partition Image, see the OS Partition Update chapter.
An OS Patch is used to apply enhancements or bug fixes to the OS image on an Oracle SD-WAN Appliance without requiring a full OS update. For instructions on how to install an OS Patch, see the OS Patch Installation chapter.
- Customers who would like to take advantage of the enhanced security and stability of Oracle Linux based Oracle SD-WAN Edge OS 7.0 and who are willing to run Oracle SD-WAN Edge 8.2 GA (or later) on their network. Please refer to Oracle SD-WAN Edge OS 7.0 Release Notes for more details.
Supported Software and OS Combinations
The following devices are supported by this OS release. If an appliance is not listed, it is not supported by this OS version.
- D2000
- D6000
- E50
- E100
- E500
- E1000
- T860
- T3010
- T5000
- T5200
- CT800 AWS
- VT800 Hyper-V
- VT800 Azure
- VT800 ESXi
- CT800_128 AWS
- VT800_128 Azure
- VT800_128 ESXi
- VT800_128 Hyper-V
Enhancements/Features in Oracle SD-WAN OS 7.0
The following items are new in this release.
Oracle Enterprise Linux
- ID: 19324
Enhancements/Features in Oracle SD-WAN OS 7.0.1
The following items are new in this patch release.
Collecting ILOM Diagnostics for D2000 and D6000
- ID: 30897344
Known Issues - SD-WAN OS
This table lists the known issues across this version of SD-WAN OS.
| ID | Description | Severity | Found In |
| 31000664 |
There are two work-arounds to this problem.
3 | OS 7.0.1 |
