Oracle Cloud Marketplace Support
SD-WAN Edge virtual appliance is available for installation directly from the Oracle Cloud Marketplace. Installing SD-WAN Edge from the cloud marketplace simplifies the process and lets you run your application sooner.
An OCI account is required to use the marketplace. Search for "Oracle SD-WAN Edge Virtual Appliance" on the Marketplace web site.
Initial sign-in to SD-WAN Edge on OCI
When you sign in to SD-WAN Edge virtual appliance for the first time,
a default username and password are provisioned. These are:
- Username: talariuser
- Password: talari-[first 8 characters of OCID string]
For example, A Virtual Appliance with a VM OCID of ocid1.instance.oc1.phx.anyhqljs q5fbg5acabkpupy4ew2rickxhkcnuqmqtxdrshbyi25umjngtnh2 would be accessible via the user "talariuser" and password "talari-anyhqljs".
See Where to find your tenancy's OCID for more information.
Refer to the following resources for more information.
