WAN Optimization System Specifications
WAN Optimization is supported on VT800s running Edge 7.1 or above and VT800-128s running Edge 7.3 P4 or above at the following levels with the specified resources:
Platform |
License Level |
WANOp Capacity |
VCPUs |
RAM |
Max WANOp Sessions |
Disk Size |
Cloud Instance Type |
Hyper-V |
20 Mbps |
8 Mbps |
2 |
8GB |
1,500 |
160GB |
NA |
200 Mbps |
100 Mbps |
10 (2.10GHz) |
10GB |
5,000 |
160GB |
NA |
Azure |
20 Mbps |
8 Mbps |
4 |
28GB |
10,000 |
160GB |
DS12_v2 |
500 Mbps |
100 Mbps |
8 (2.4GHz) |
56GB |
16,000 |
160GB |
DS13_v2 |
ESXi |
20 Mbps |
8 Mbps |
2 |
8GB |
1,500 |
160GB |
NA |
2 Gbps |
200 Mbps |
14 (2.10GHz) |
16GB (VT800-128: 32 GB) |
10,000 |
160GB |
NA |
The maximum number of WANOp sessions is scaled based on available memory. If a virtual appliance has insufficient dedicated RAM, the maximum number of WANOp sessions will be lower. Provisioning a virtual appliance below recommended system specifications will not disable WANOp, but will impact WANOp performance. Provisioning a virtual appliance below the defined minimum specifications is not supported.A warning banner will be displayed in the Web Console if WANOp is enabled on a Virtual Appliance that does not meet the minimum recommended system specifications. An example is shown below, on a VT800 with insufficient RAM and VCPUs:
For information on how to configure WAN Optimization, please see the WANOp Setup and Configuration Guide.
