DHCP Relay
Network administrators can now use the DHCP Relay service on data ports of Appliances to relay requests and replies between local DHCP Clients and a remote DHCP Server. This allows local hosts to acquire dynamic IP addresses from the remote DHCP Server.
To configure DHCP Relay, navigate to Sites > [Site Name] > DHCP. Expand Relays then specify the data ports to be used and the Server IP address.
