Oracle SD-WAN Edge as an Autonomous System (eBGP)
6.1 adds support for using Oracle SD-WAN Edge as an Autonomous System (AS), which behaves as a contiguous AS from a BGP perspective.
The primary use-case intended for Oracle SD-WAN Edge as an AS consists of the NCN and Geo-NCN configured as Route-Reflectors, and Clients using an iBGP peering session to the NCN and Geo-NCN for BGP reachability information.
To configure BGP using Oracle SD-WAN Aware, navigate to Manage > Configuration and Import the current configuration file from the Active NCN to get started.
