Fail to Wire Copper (4 Port) Expansion Card
The configuration editor will not detect which expansion card (if any) is installed on an E1000, and will offer port 1 – 12 for all E1000s.Before beginning configuration for an E1000, please verify the physical ports on the appliance. The following ports may be configured for each hardware option:
Hardware Option |
Ports |
E1000 without expansion card |
AUX, interfaces 1-8 |
E1000 with 10G expansion card |
AUX, interfaces 1-10 (ports 9 and 10 fail-to-block only) |
E1000 with FTW expansion card |
AUX, interfaces 1-12 |
If a configuration that does not match the available hardware is applied to an E1000, the Oracle service will be disabled. Once a mismatched configuration has been applied to an E1000, a corrected package must be applied through Local Change Management before the Oracle service will start. Alternately, the appliance may be factory defaulted and a corrected configuration applied using the Easy 1st Install process. The Oracle service will be disabled until a corrected package is applied.
For more information about the E1000, available hardware options, and special configuration considerations, please see the E1000 Installation Guide and the E1000 Hardware Guide.
