Configuring WAN Optimization via Aware
Using the web UI for Aware, navigate to Manage > Configuration and Import the current configuration file from the Active NCN. On the Advanced tab, under Global > Default Sets > Conduit Default Sets > [Conduit Default Set] > Rules, click the (+) icon to create a rule for the type of traffic to be optimized.
Expand the rule properties. WAN Optimization is enabled via a dropdown menu under the WAN General section. When WANOp is enabled, TCP Termination is also enabled by default.
When WANOp is enabled, TCP Termination is enabled for WAN Optimization to function as designed. If desired, the user can also enable TCP Termination independently from the WAN Optimization capability, as shown above.A reciprocal rule enabling WANOp will be generated automatically at the remote site of the selected Conduit.
Once your configuration is complete, Export it to the Change Management inbox and follow the prompts through the Change Management process until the new configuration has been Activated.
